So during a ride a few weeks ago my board started acting weird so I stopped to check and left motor was not spinning and making a loud noise. I assumed my motor just died on me it was an older motor so I was okay with that. Yesterday I install a new motor do. Motor detection and the same noise happens again same side.
I check fault codes and see this
Same DRV on each side as before afaik? with single MCU. Shouldn’t have thought much difference in susceptibility to drv error, apart from better cooling?
Were you cranking it on with strong settings & 300lb iirc?
Not even, I have pushed alot of power through the unity np but it failed while I was derping around in a parking lot right before the group ride going less than 10mph
Guys as I said to many customer DRV_ERROR does not necessary mean that the DRV is blow, like a check engine doesn’t mean that your engine is completely dead. It could just be a resistor or a cap that is sightly damage. Could also be just a mosfet.
LOL probably not. I’ve seen bigger people ride unities.
indeed. first thing i would do is re-flash the firmware and see if it just made itself stupid. That happened on the group ride in colorado with @RuinousMarmalade 's board, very similar symptoms. I flashed it and re-ran detection and set her up again and she was fine.
ok now that i see that pic, maybe flashing won’t help. Either way, i seriously doubt the rider’s weight had anything to do with it. it kind of does look like a short of some kind.
