I got these hellcats hubs I was trying to use on my hypertrucks. but they are binding.
split in half each bearing fits on the axel no problem. together however they bind to the axel. This suggests the bearings are not seated our out of alignment.
How do I reseat/adjust these bearings? I see no way to get behind them and drive them out.
One of the four hubs fits on the axels without binding. the other three do not.
all of the hubs fit on MBS trucks without binding.
the easiest method is to attempt to reseat the bearing square from the outside of the hub with a socket, the second easiest is to find an appropriate socket to the inner race and tippy tap on it from the inside… don’t go blacksmith on it… go gentle and rotate the bearing a 1/4 turn or so after every tippy-tap… it SHOULD start to come out…
if it doesn’t move, don’t fukkit up…
just lemme know if it seats from the outside, or becomes unseated when motivating it from the inside…
there are still plenty of options
EDIT:
Zach has a thought… try all hubs in all configurations… I’d still attempt to fully seat the bearing first in any case
Yeah. You can tell tolerances are pretty tight with those hubs. But I’ve also seen people having binding issues with Hypertruck axles and Lacroix own 72t wheel pulley.
How old is the Hypertrucks? On the initial batches we had a problem with the tolerances on the axle that needed a bit of sanding, this was done on our boards, but I’m not sure on just the trucks
but… the bearings slide onto all the axels individually. it’s only when paired through the hub to the other bearing that the binding is happening. (see vid)
