HuX FluX ElectroluX
Min street board is a 13s6p with maytech 150kv motorer and a BioX esc. It’s set at
Motor current max 58,98
Motor current max brake 58,98
Battery current max 84,00
My carver is 16s6p with Go-foc d75 and SKP 205KV motors.
My current setting with the Flipskys 190kv is:
Motor current max 80
Motor current max brake 60
Battery current max 50
What are your thoughts on these settings?
If that’s more than enough for you I wouldn’t change it. But by going to 205kv you technically lose a bit of torque, it’s probably minuscule. If you care maybe bump motors to 85a?
So I could just go by trial and error?
How far can I push the battery max amps?
I don5want to wreck anything.
I forget what battery max amps are for D75 (and it’s no longer listed on their site @Evwan might remember), but honestly you can probably keep that the same for now as that is torque at high speeds and motor amps is torque at low speeds. But yes you can play around with it until you have what you like without going beyond the limit of 120a of course.
Battery amps were never listed for the d75. I ran mine at 50 per, but I suspect you can prob do 70 per side
Thank you! I reached out to Maker X.
Your estimated guess was spot on. 70 is probably the highest i will go.
Yeah the word ‘about’ would make me want to set to 70 too haha
Next step on the never ending journey of eskate.
It made a big difference though.
Took me eight minutes to cook the motors.
Bye bye 120A…
d100s reacher motor upgrade time?
I just bought these :joy:
your motors not having vents like the reachers is most likely caused them to run so hot
I have Reachers.
Is your thermistor beta value set right in vesc? May be reading wrong. For firmware 6.2 it’s in motor cfg → temperature, in older it’s in motor cfg → advanced
Stock thermistor value is 3380
Flipsky is 3455
Reacher is 3950
I was certain that I had changed it to 3950 but i double checked it now and i hadn’t.
Thanks for the heads up!
Do you know what the value ahould be set at for maytech motors?
ahh here it is. have you done another ride on the new settings?
