Now that the Unities are no more, I want to protect the one I have - Are there recommended safe settings that will prevent me from frying it given my setup below? Also if there are any FW versions I should steer clear of. Total beginner when it comes to the Unity setup.
My current setup:
- 12s4p 30Q pack (TB prebuilt) (BMS - 60A continuous, 150A peak)
- 2 x TB 6374 190kv motors
I am pretty much using the default settings of 60A max bat discharge, -30A regen brake, max motor current 60A and max brake current 60A. Iām pretty sure these are all under the specs of my gear?
And of course, minimize vibration, heat, water ingress.
Thanks,
