I’ve been trying to figure out how to fix this. Essentially, I can’t fully charge my battery. I have two builds, had the same issue (could only get about 80% charge on 12s2p 40T packs). After updating my vesc 6 mk3, that build started fully charging. My second build uses a storm core 60D+ now, but I still can’t get the battery to fully charge. Both packs were purchased from ChiBoards. I know the packs BMS are Charge Only. I put the battery info the same (8ah) within the esc setup. My charger stops charging automatically, so I pretty sure the pack is full even though DAVEGAX reads 80%. Any help would be appreciated
I had the exact same issue with my very first pack. I thought that was the problem because my original pack fell. I bought these two packs, and had the same issue with both until I updated the VESC build FW5.2v and ran through all the settings. Now one build fully charges. And this one still only ~80%.
Can/could you open your packs and check the voltage of the pack with a multimeter? If it goes up 4.2 volts it’s good if it goes up by less than 3 volts it’s probably not a good sign
I just took the Voltage meter to the pack, only 47V fit the entire pack. Maybe my pack does have a bad group. I don’t feel comfortable Opening packs. Not trying to burn down apartment. Anyone know if proven Battery builders in NYC area that can check the pack out?
