I’ve hit a snag.
@NoWind - should I have expected some long M4s to fasten the wheel drives with?
Watching as well sweet looking build
Have you figured out how to mount the wheel pulley to the hub yet? I have an e-toxx MBS chain drive kit on the way and am very interested on the mounting procedure for the pulleys to the hubs as well.
I would first mount the hubs with the stand offs than the sprocket. Get some m4 screws which are 5mm longer. Should be fine than.
Nice build buy the way
Remove your locknuts and then you put in the Hex Spacer !?
Vtc6 all the way!
Why, to get a capacity loss of over 25% after 50 cycles?
Sony VTC6 LG HG2
Cycle Capacity % %diff Capacity % %diff
1 2328 100,00% 2225 100,00%
2 2318 99,57% -0,43% 2190 98,43% -1,57%
3 2292 98,45% -1,12% 2190 98,43% 0,00%
4 2278 97,85% -0,60% 2173 97,66% -0,76%
5 2268 97,42% -0,43% 2173 97,66% 0,00%
6 2251 96,69% -0,73% 2170 97,53% -0,13%
7 2235 96,01% -0,69% 2129 95,69% -1,84%
8 2229 95,75% -0,26% 2141 96,22% 0,54%
9 2239 96,18% 0,43% 2134 95,91% -0,31%
10 2218 95,27% -0,90% 2118 95,19% -0,72%
11 2212 95,02% -0,26% 2145 96,40% 1,21%
12 2207 94,80% -0,21% 2111 94,88% -1,53%
13 2202 94,59% -0,21% 2118 95,19% 0,31%
14 2190 94,07% -0,52% 2128 95,64% 0,45%
15 2183 93,77% -0,30% 2096 94,20% -1,44%
16 2179 93,60% -0,17% 2119 95,24% 1,03%
17 2177 93,51% -0,09% 2101 94,43% -0,81%
18 2173 93,34% -0,17% 2106 94,65% 0,22%
19 2163 92,91% -0,43% 2107 94,70% 0,04%
20 2145 92,14% -0,77% 2055 92,36% -2,34%
21 2150 92,35% 0,21% 2106 94,65% 2,29%
22 2135 91,71% -0,64% 2106 94,65% 0,00%
23 2118 90,98% -0,73% 2079 93,44% -1,21%
24 2108 90,55% -0,43% 2096 94,20% 0,76%
25 2083 89,48% -1,07% 2111 94,88% 0,67%
26 2139 91,88% 2,41% 2114 95,01% 0,13%
27 2119 91,02% -0,86% 2117 95,15% 0,13%
28 2106 90,46% -0,56% 2100 94,38% -0,76%
29 2091 89,82% -0,64% 2063 92,72% -1,66%
30 2089 89,73% -0,09% 2079 93,44% 0,72%
31 2080 89,35% -0,39% 2072 93,12% -0,31%
32 2063 88,62% -0,73% 2061 92,63% -0,49%
33 2046 87,89% -0,73% 2061 92,63% 0,00%
34 2058 88,40% 0,52% 2045 91,91% -0,72%
35 2061 88,53% 0,13% 2046 91,96% 0,04%
36 2039 87,59% -0,95% 2033 91,37% -0,58%
37 2006 86,17% -1,42% 2034 91,42% 0,04%
38 2000 85,91% -0,26% 1990 89,44% -1,98%
39 1996 85,74% -0,17% 2007 90,20% 0,76%
40 1967 84,49% -1,25% 2025 91,01% 0,81%
41 1939 83,29% -1,20% 2006 90,16% -0,85%
42 1916 82,30% -0,99% 2016 90,61% 0,45%
43 1902 81,70% -0,60% 2002 89,98% -0,63%
44 1896 81,44% -0,26% 1996 89,71% -0,27%
45 1852 79,55% -1,89% 1979 88,94% -0,76%
46 1834 78,78% -0,77% 1973 88,67% -0,27%
47 1822 78,26% -0,52% 1960 88,09% -0,58%
48 1799 77,28% -0,99% 1954 87,82% -0,27%
49 1750 75,17% -2,10% 1945 87,42% -0,40%
50 1727 74,18% -0,99% 1934 86,92% -0,49%
IIRC the 30Q has a loss of aprox. 5% after 50 charges. Their is no better 18650 cell for ESK8 right now.
what enclosure is that 3d servisas on the back?
That graph say it starts at like 2300mah. The vtc6 is 3000mah. Yes from what I have seen the 30q has a better life cycle but the vtc6 has a higher output. I currently only have 30q packs but I just bought a ton of vtc6 cells for super cheap. I will soon be able to test for myself if they truly degrade that rapidly.
They charged the cell to a certain voltage and than compared the life cycle.
The result was after 50 cycles 1727mah 74,18% -0,99% for the VTC6 and 1934mah 86,92% -0,49% for the HG2.
Any context around that?
What was the discharge/charge rate at?
Does it really make a difference in our not linear discharge?
Wouldn’t be so sure about it.
I definitely would put vtc6 on one level with 30qs.
Winner is the one which you can get cheaper.
Take the test with a grain of salt. The test I just looked at the vtc6 cell was incredibly abused at a constant 15a drain and 4a charge for 50 cycles and only lost 11% capacity. The 30q only lost 6.9%. There are pros and con to every cell. Vtc6 has a higher discharge rate, less voltage sag. The 30q has longer life span by a few %. So it lost 11% capacity after being completely abused. Esk8 you aren’t abusing the cells anywhere near 15a constant discharge and nobody I know charges 4a per cell( that would be a 20a charger for a 12s5p). I myself use a 3a charger so thats .67a per cell. There are just trade offs between each cell.
Also I got the vtc6 cells because I got them for $2.59 per cell. The cheapest I can find 30q cell is $4.50 with moq. Fyi nkon doesn’t ship to the United states anymore so I got the best deal I could find and stocked up with 400 cells.
Merci cher Monsieur!
Most manufacturers take the 30Q for reliability reasons and the good life span.
It is by far the safest all around cell out there. If you have lower power setup or very big batteries (8p+) you can also use 35E. Samsung is leading the battery industry anyways, so there are multiple reasons to get the 30Q over any other 18650 cell.
Ok availability and price are legit reasons to go with another cell. A good over all alternative is the 40T if you can go 21700. Sanyo 20700B are also great cells, but I wouldn’t recommand any other cell for general purposes.
The VTC6 is a great race cell though, if you want to go with LiIon. But in race cases I probably would prefer LiPo anyways.
Sorry if I… but there some things I don’t want to let stay here like it is
Any backup to this statement?
Like any other cell which has around 8-10A.
By the way I personally wouldn’t use the 35E even on a 8p pack. Maybe on a 10p plus pack, but than there still cheaper options available.
No. There is no advantage on 40T cells over your beloved 30q. The only advantage they could bring is if you make a flat pack and can’t double stack but fit 21700 cells.
Compared in proper relation the 40T will lose over the 30q.
No? What’s with vtc5, vtc5A, lg hg2 just to name a view.
It’s even not the best cell Sony sells, so no it‘s not a race cell.
Yes, like I said. Check out what most companies are using in their ESK8. Even in DIY it is the most used cell. It’s proven tech.
ok
Sure. It depends what you are meaning with proper relation. The 40T has higher current and capacity per l and per g.
They are good cells but wouldn’t recommand them if 30Q are available.
ok.
Ok that’s an scientific evidence
Ok. Let me check, 40T 25-30A discharge 70g… 30Q 20A discharge 50g … 0,42 to 0,4… **you right **
Looks like a significant advantage.
Let’s just have a short look at the price tag thou. 40T 4.75€, 30q 2.80€ (nkon price) that’s 0,06€/g vs 0,04€/g so 1/3 more expensive.
