I swear my new build is haunted. It’s been having all sorts of issues that seem unrelated. It initially had a unity and a VX2 pro on the last unity firmware.
- Issue 1: The VX2 would show 0 bars intermittently if I raised it up to look at the screen, but would instantly show three bars if i lowered it to my side.
- Issue 2: The motors would also cut out for a tiny bit while riding normally and then come back almost immediately. I initially thought that this was related to the first issue, but the cutouts were happening with the remote at my side.
So I upgraded to Vesc 5.10 firmware to see if that would clear the issue and to use the new stormcore app. The upgrade process took its sweet time, but completed without issue. I ran motor detection again and checked the settings to make sure that nothing had been reset in the upgrade. I noticed another issue at this point.
- Issue 3: My android phone would intermittently disconnect from the Unity bluetooth module despite being 5 feet away from it
During these runs I was also testing the new stormcore app from @sofu on my iPhone.
- Issue 4: Stormcore app would recognize the Unity bluetooth module, connect to it and function, but would stop recording shortly after starting. I set the location permission to “always allow” before the first test and this happened anyway. It would also disconnect from the board if I was in the app for more than a minute. I don’t think these issues are related to the app itself, I think they merely illustrate issues with the bluetooth module.
After a few test rides with the new firmware, issues 1 & 2 were still occurring. So I ordered a VX1 PPM to replace the VX2 pro. During the install, I also added a Metr.Pro (with long range antenna). After the install, I used VESC tool mobile to configure the PPM settings.
Issue 5: The VX1 PPM output was all over the place. With the throttle at rest it would swing between 1.07 and 1.32 ms. My other VX1 (also on a unity) only swung between 1.50 and 1.51. I had to set the throttle deadzone to 20% to prevent the motors from stuttering.
Issue 5.1: During the only test ride with the VX1, the throttle seemed very unstable and would vary by up to about 10% faster or slower.
Issue 6: The Metr.Pro would also not stay connected. I started a recording during my only ride after the VX1 upgrade and it only recorded for ~45 seconds before it too lost connection.
At this point I think it has to be the Unity that’s having issues because that’s the only common factor among all of these issues.
Does the hive mind have any great insight into what may be causing these problems?
