FS6354 not preforming?
Hey guys,
I’m finishing programming my vescs. However, the motors seem like they’re not performing at standards. They have very little torque at low speeds and only reach 24mph with a 10s4p battery (16/36). What settings should I change?
Bumping this
Well what are your settings? Hard to say change this without seeing them
Dude. No. It has been 30 minutes. Consider the reason you have not gotten an answer to be your fault not others for not seeing the post.
You need to post settings, give us data from the vesc tool, what the current settings are, etc. You didn’t even give enough info to get a speed calculation.
Not to be rude, but you need to read before you post. There’s shitload of information on this forum and the old one, start searching and reading, bring your own conclusions to the table and ask what others think of the problem and proposed solutions. Help yourself before you ask for help, the community is here to guide not instruct.
Also what controller are you using? some controllers have speed mode settings
Well I’m new to this so I don’t know what settings to tell. There is a lot of settings I don’t even understand.
Flipsky VX1. The speed modes do not effect the speed at all
Find:
Motor current max: ?? amps
Motor current max regen: -?? amps
Battery current max: ?? amps
Battery current max regen: -?? amps
post all the settings you are using
Motor max is 45 and battery absolute max is 160. I believe the motors can handle 65. I have a 10s4p vtc6 pack so I think I can do about 80+ amps (I think).
I also have traction control on and current is in foc mode
do you have bluetooth or are connecting to vesc tool?
24mph is not that slow, and you are on 10S
your settings might not be calculating the speed right too
Connecting through micro usb
We want to work with you just try to be a little more considerate You come in. One minute knowing everything and then the next minute you’re a noob just chill don’t get defensive just try to do what these guys say they’re trying to help you out
My 2cents :call_me_hand:
what is the max duty cycle and erpm?
fully charged
The VX1 speed modes 100% do effect the speed… Are you using UART or PPM? Have you opened the app and checked what PPM mapping looks like on all 3 modes? Highly suspecting it was setup wrong
How do I check the mapping per mode? I’m in this screen right now:
and yes, I’m using PPM
I haven’t fully changed the battery yet. I’ll do that though.
I can see those PPM settings are default, that is the issue. Do the input wizard setup and make sure the remote is on the red mode when you do the PPM max-min mapping
Ok let me try again
