Hello,
I have a diy dual VESC-X setup that i’ve been running for a while. I was using the board last weekend and hit a slight bump, and the brakes locked up. I stopped and restarted the board, and noted that the master Vesc powered on but the “signal” light was off. The secondary Vesc has both lights on as normal.
I got home and plugged in the master Vesc and it doesn’t acknowledge the USB at all. The secondary vesc still connects fine and appears to be working. Any suggestions?
Thanks
