Anybody know if there’s a converter for the focbox motor wires to fit the TB motors? Really don’t want to cut them and solder new connections.
If you can find a 4mm(?) to 5.5mm bullet adapter yes but that adds unnecessary resistance and failure points.
Just solder new ones. (no need to cut them)
good iron can be had for cheap these days.
I got a sq100/ts100 and it does great with the right power supply.
Damn that’s exactly what I was looking for, out of stock
Make your own? 3.5mm and 5.5mm bullets, 6 pieces of equal length wires and some heatshrink
honestly, the easiest thing would be just replace the connectors on focbox
Yeah that’s what I’ll probably end up doing.
i’ve replaced mine with all 4mm bullet connectors, but since OP is asking for “converter” then i have to provide a converter solution
I’ve always ended up super lucky. Never had to change a connector. They always match
Sensor wires…are another story
that’s lucky, i’ve had 3.5mm to 5.5mm connectors i have to deal with, so i got mad and change all of them to 4mm
those are expected
If you really want I’ll make you a set, I guess I’ll match the TB price and $3 to cover shipping in the states ($8 if you want to expedite it) sound fair?
I’ll take you up on that! It’s for my cousin. I have a torque6 ESC, he should’ve just went with that haha.
But he’ll probably want the expedited shipping! All his stuff comes in tomorrow.
what’s the connector on that?
Sure thing, $16 F&F and I’ll send it tomorrow morning. I need and address and a wire length, also what gauge do you want?
fk, so i need to change them to 4mm…wonderful
cut/solder new bullets will be faster and cleaner than making an adaptor. I or someone could make you one if you know the sizes
lol… might have grabbed the last one
