please tell me what the worse thing about it is, from first glance. pppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppp
I had one weird disconnection on my first real ride with my VX1. Kinda like @Jinra discribed with his I sloweed down to a stop then had no throttle. Reboot remote and go. I blame my sketch wiring but I digress.
Wow! Great part selection! 4WD on foamies, 200A cells, and this is your first build?!?!?! This is starting to smell like a contender for build of the year to me! Bookmarked!
haha yeah I think the funny thing is I would be very hard press to find many other boards as powerful as this. Plus a lot of them have heavy high capacity li-ion packs, some have Lipo yeah. My point is I think the power to weight on this is something special for sure.
I’m starting off a bit large.
It throws you off HARD
need to lower brake current from 100A down to like 50A
I think if I threw some 90mm wheels on there I could pull something big. My plan is to try to have someone pull me on my freebord using an AWD setup like this.
had to tone it down a lot, also figured out I had celebrated my remote settings while not on the max speed mode. So I got them all recalibrated and lower power with less braking and a slight -15% curve on fwd and rev.
I decided to cut the thumb off my glove, so I’m hoping for a better experience tomorrow. Oh and got velcro glued to the remote.
To answer your question I accidentally made a 13S but it’s a 12S now. Make sure you count your cells not follow the balance leads/wiring diagram. That can be confusing.
They stack up for sure, but the energy density is bad. I am going to test out how it does with a charge and ride system, which is what I think it’s strong suit is.
