Before I tried frit on a new deck I wanted to test the process, I did all this without looking up how to do it and just from memory, some practice before try something similar with my Tayto deck.
Have to say this took much longer than I expected but I found it really satisfying - I think none really gets the effort that goes into a @Sender -ized board
I wanted to use something disposable, decided on an old meepo campus board I had no use for…
removed the grip
gunk was a pain to remove…
I used a pencil eraser
tuned out pretty nice
did a little sanding
the epoxy I used
I went for fast, mainly due to temp in Scotland would need heaters to get to 25 Deg.
first coat epoxy
the firt i wanted to play
these are Rainbow on Black Dichroic flakes, silly expensive but sooo nice
sanded, then did a coat epoxy and let it get tacky
so this is where I am pretty sure I went wrong - material has too much texture and is too dark, this was with a flash
one coat on material, texture is so obvious already
right I’ll add another coat just to see if it helps, at this point i did think that I might not even need to add frit its so textured lol
so at this point I’m actually feeling quite confident…
some sanding and things are looking ok
after I’ve sanded to its as clear as possible I add some frit
these were all ‘medium’ I used more cobolt than black and purple but they just seemed much bigger
at this point im quite happy
tidy the edges after a final coat epoxy
so the problem is that after the last couple coats its not really possible to see thru the expoxy anymore
I used a few Dichroic flakes to see how they would look
as far as the frti turned out I’m really happy
resin is fun. I really like the texture that comes out on top of the fabric, im gonna try and keep a but of that when i frit mine
