Hi guys, I’m trying to make some space, so these are some small things I can pass to somebody else
shipping from czech republic
Item 1
Description: Redember 44 blue
Price (CZK): 8000 + shipping
never ridden, paint has imperfections from other deck touching it. truck mounting holes on one side are not 100% matching truck pattern. they are about 0.5mm off. is usable with slight persuasion
Item 2
Description: Kegel core wheels - 120mm rubber (Flash/Jetsurf) new, 80mm Kegel used, pulleys and belts
Price (CZK): 2200 + shipping
including these pulley sizes (3dprinted, HTD-5M)
- 32t 2x with adapters to other side of the core
- 34t 2x with adapters to other side of the core
- 36t 2x with adapters to other side of the core
- 38t 2x with adapters to other side of the core
- 40t 2x with adapters to other side of the core
two pulleys are also already attached to the kegels. two kegels are without pulleys (diffrent than the picture says)
including these belt sizes (HTD-5M, 15mm)
- 320mm 8x
- 310mm 2x
- 300mm 2x
- 290mm 2x
- 270mm 2x
Item 3
Description: Trampa butt protector (new, never used)
Price (CZK): 600 + shipping
wanted it for racing, so that falls on my butt are feather-like. then I stopped racing
Item 4
Description: complete set of things for vacuum molding of enclosures with GF and CF
Price (CZK): 6000 + shipping
complete set of stuff you’d need. there’s enough GF and CF for multiple enclosures (at least 3).
- GF in two weights (140g and 350g)
- CF in two weights (cannot remember)
- anti-sticking perforated blue plastic between infused GF/CF and a bleeder
- anti-sticking non-perforated blue plastic for whatever survace you dont want coated
- bleeder cloth
- separator coating
- 1kg of unopened epoxy with hardener
- vacuum bags
- the stickiest tape ever for sealing the vacuum bag
- vaccum pump
- pain rollers for the epoxy, with a tray
- blue and black pigment
- cups and sticks to mix the epoxy
Item 5 [SOLD]
Description: MBS F5 bindings with heel straps
Price (CZK): 1200 + shipping
riden only once. I found out that I like to get off of the board while riding in the city.
I got some spare ratchet-teeth-mounting-straps, so they’re going as well.
Item 6
Description: street complete 12s7p 30q, unity, 6374
Price (CZK): 18000 + shipping
a street board that needs some attention.
specs:
43" Grand plata deck aka MBNEF
Focbox Unity with heatsink and BT module
Maytech 6374 170kv
12S7P 30Q battery
xiaoxiang BMS
gearing 16-40,
240mm 3DServicas trucks
110mm TB thanes
with 90kg rider goes ~50km, max speed around 50kph
there are two issues:
- one mount is broken. should be able to order new one from boardnamics. the claps are made to fit the 3ds trucks, so only the plate is necessary
- motors are getting old, and are probably missing few pieces of magnet. HFI cannot make them run from dead stop. they need slight push. but once they spin, they run well
(btw the “Driveto” logo is a stricker and can be removed)
