So I am selling my Aileron.
My dad offered me 500 to build him an esk8 and I took the opportunity to buy an Unlimited x Loaded Solo Kit
It didn’t suit him because we have a few hills and he is 80kg so a single drive is limiting.
It’s a shame because i thought this board would be ideal with all my competitions and travelling since this thing has a detachable battery that is air travel-friendly.
Note that i did pull this kit apart to have a good look at things and i can say it’s designed beautifully!
See my thread here, I also conformally coated the ESC, which was totally unnecessary since the whole kit is IP65 from memory, but anyway haha, it’s super waterproof.
I also noted that is you know how to weld a battery, it’s really easy to replace the 25r with 30Q, i even asked the cofounder by email and said that it’s totally possible, but it might slightly overheat quicker and will reduce speed automatically to avoid thermal throttling but it would increase your range.
The whole Board weighs in at mere 5kg
It has less then 15km on it, trucks are Paris V3 180mm with riptide bushings.
Comes with a spare new sleeve.
Also has front and rear surfas trident lights that cost 80euros
It also has an app where you can choose different speed modes, or even completely customize your mode.
It really is quite powerful too, me at 60kg pulling the throttle made me fly off it lol. it did a wheelie on me
This really is the perfect budget commuter, especially if you travel by air a bit.
Hope this finds a new home, because i find the whole board really cute lol. in fact I’ll supply some googly eyes
I also might have a special unreleased app that i can give. It allows you to adjust ALL settings like a vesc tool. Very interesting if you want to change the battery for some oomph.
Of course this means there is no warranty on it, but there is none anyway.
It’s built like a tank though
You’re foot is mostly on the kicktails, but then I don’t know how to slide so I might be misunderstanding, I’ll go measure for you
As for toe bight I have not had any and I have had the bushing so it’s really carvy
please do… I really like the looks of the Aileron but I normally ride over the trucks on short-boards… and I get nasty heel-bite sliding my little board… and NO i’m not going to add a butt-load of risers…
No going to lie, there is some riser because you have to put some for the kit. About 1cm or riser I guess but I’m no where near wheelbite
This is full lean heel side with current bushing setup. To give you how loose it is, I get speed wobbles at 26km/h
buy it and see
i have a normal stiffness and I’m 60kg. it flexes a little but as @Linny said it’s a weird flex, only happens when you use the kicktale. it flexes just in front of the rear truck, like a U shape
