An enclosure with built in threaded inserts that can fit a 12s2p battery and an esc.
I don’t think the Meepo one I linked can fit my battery and esc. It would need to be about 12 inches in length and the height of 2 18650 cells stacked on top of each other. It also needs to be shorter than 23 inches in length.
I don’t mind spending a bit more. 150 is probably my ceiling, but Im trying to move away from having the inserts in the deck since I swap boards a lot and it makes it pretty inconvenient if I have to measure, drill precise holes, screw inserts etc. Hence why I’m asking for ones with captive inserts
Ideally it would also have a bottom cover so that the unit can be sealed in itself. That was I don’t have to worry about gaps between the deck and enclosure. Different boards have different shape/concave.
It’s unlikely you can find an enclosure with threaded inserts. I would recommend getting a Pelican case or similar hard plastic case and epoxying insets inside of it. I can make you a 12s2p pack to go in it if you can find an appropriate sized case
I used a Verreal f1 enclosure that had built in threads. Didn’t love drilling through the deck but it’s an all metal enclosure and does the job for cheap.
Double check measurements but I believe it should fit.
Thanks for this mate! A metal enclosure was also a secret wish I had for this post.
I think for my battery to fit, Id have to reconfigure it as a one stack. It looks like the height is short by .6cm for my double stack. I suppose I could learn how to do that.
Does it come with scews? If not what size are they exactly? Standard skateboard 10-32 thread?
