EMB Misc Parts & Accessories (US) - MBS Comp 95, BMS, Gears, Remotes etc…
Have a bunch of things I no longer need, most are brand new.
Located in Tampa, FL if you want to pick up otherwise shipping is included in the prices of everything but the Comp95 Board.
Garage Sale (US) Remotes, BMS’s, Gears, ESC, etc…
$200 + shipping –
MBS Comp 95 Board – great shape but I have too many. Will come with MBS Velcro Bindings but the orange gears/pulleys are not included. (see below, selling some)
Lowered to $60 shipped ($55+ shipping worldwide) (US) –
Enertion Nano-X Remote – like new, used it for one ride while I was waiting on my flipsky. Looks and performs as new and includes everything.
SOLD Broken FOCBox Unity – since I am clearly not going to get my paid replacement from Enertion so theres no sense in keeping this. Not sure if anyone is able to fix them but figured it’s worth something. Has Bluetooth module that can be easily used on other setups so make me an offer!
$20 shipped (US) -
Waterproof remote from ebay. Brand new, only has FWD, didn’t realize until I got it. Wireless charging, comes with everything needed – plug n play
$50 shipped (US) -
Ebay ESC w/Remote
Brand new, used this once on a test board running a 10s2p lithium battery and planned to use it on a build but I never did. Below is the description from eBay:
24-36V Electric Skateboard Controller Dual Motors with Remote
Specifications:
Remote controller: 1005220mm
Control panel: 10076mm
Thermal baffle: 8059*3mm
Input Voltage: 6S-10S
Please note that this control module have hub motor version and for normal brushless motor version.(like 5065, 5055, 6354,6364,6374…motors)Max power output 1300W. (600W each motor)
The control board is compatible with 24 to 36V voltages, there’s no need to change the voltage. The control board and remote control have been connected to the code before delivery, and the remote control will automatically connect with the control board after starting up. Automatic connection need not yards.
$15 shipped (US) -
Lithium-ion 10S 16A BMS with Balance, waterproof, Single Port (Charges to 42V)
Data Summary INR-10S-16A-S
Charge Voltage: 42V (4.2V per cell ± 0.05V)
Max Continuous Discharge Current: 16 Amps
Peak Discharge Current: 50 Amps
Charging Current - up to 16 Amps
Operating Temp Range – (-30°C to +75°C)
Cell Balance Voltage - 4.2V per cell ± 0.05V
Over Current Detection Delay Time - 9ms
Balance Current 35mA ±5mA
Over Discharge Cutoff - 2.8V ± 0.05V
Size: 62 * 37 * 9 mm
$45 + shipping EACH (US) –
These are fully adjustable universal steering dampers (steering stabilizers) for motorcycles. I bought these with the intent of putting them on one of my road boards for speed but after my first crash I decided there was no need to go 60 on a mountainboard. They are both brand new.
$30 shipped (US) –
Brand new, never needed - 10S 45A BMS PCB PCM Li-ion Lipolymer Battery
This is a 10s 36V-42V lithium battery power protection board. With a balanced, same port 45A discharge. Size: 120 * 60 * 9mm. with Cable, length is 300mm.
Protection board with overcharge protection, over discharge protection, over current protection, short circuit protection, temperature protection. (see spec sheet below)
$35 + shipping (US) –
72T Wheel Gears for MBS Wheels (hubs) with 6/32 inserts. The orange ones were used for a test run around the neighborhood but the others are new. Design and print these and use them on all my boards, currently have over 200 miles on one set with zero signs of wear.
PS: you can get a number of different bolts or screws at any hardware store to use on these depending on what wheel you are using.
