@magharees what do you think would be the best kv for these drives. My build currently has 190kv but since it’s an 8mm shaft I’m selling them and buying new motors specifically for this drive. My current ratio is around four. These drives are at a ratio of 3 should I drop down to 170kv?
Since the drives are expecting to be mated to a superstar hub mounting pattern you need to decide what size tire you’re going to run
6.5” - 8”
The ratio is 1:3
The spur gear are expecting a 10mm shaft on the motor you got that great.
If 8” tires are what you planning I would say 170kv or less makes sense but run through the calc so you don’t need to revisit this and sink more cash, maybe try to dig up some builds on the old forum
