Dv4s or Dv6s for these specs?
2*3000W 6468 BLDC motors
12s4p molicell p42a battery
175mm all terrain wheels
15T motor pulley
66T belt.
Thanks.
AI tells me requirements for this setup will be:
Max battery current = 50A each side
Max motor current = 90A each side
A theoretical calculation tells me the 3000W motors will draw approximately 80A battery current each.
Does anyone have real world numbers of what currents to expect?
100kg rider, pavement, hills.
Thanks
A DV4S is likely enough, but it largely depends on how fast you will ride on average and if you will have any heatsinking for the motor controller.
And what motors are those? Flipsky?
Probably DV4S. The bottleneck would be how many amps your motors can do, so if you don’t plan on running more than 100A a side, DV4S is plenty
Thanks for reply. I don’t like to ride too fast, just getting used to riding again, but do need power for hills. The board I am converting is Evolve Hadean, so it’s the stock Hadean motors. I will be changing the esc, remote, BMS.
If you’re putting it in an evolve i’d recommend the dv4s for size constraints alone
