Can I use a dual vesc to run a single motor? I have a GO - FOC DV4. I plan to run a dual motor on it but just waiting for another wheel pulley in the mail.
It should not be a problem to only use 1 side of the dual VESC. Just configure it normally, and make sure you isolate all the phase wires on the side you are not using.
*Disclaimer: unless your VESC is fucking weird and dumb.
Verify that you are using the master side…slave side might be a bit fucky with it
