DFWATTX
Built this as a V1.2 of my first board.
I started swapping unsafe diyeboard parts and came up with this
Thanks @mmaner for letting my ask annoying questions .
I drilled holes in a pelican case and mounted my unity on some industrial Velcro . Then sealed the holes with shoe goo. To keep it from running and deforming , I applied heat with a hair dryer.
I read through dofferent forums… And learned to solder on these motors . cut the brittle wires and soldered 14 ga. Awg that had more flexibility.
Mounted the motors on the trucks .
It took some fiddling to get it all trued and straight . I mounted everything and repeated the unity/ pelican case stepd with the battery . then I covered the wires and doubled the velcro with an adhesive industrial pad and a strap. Just for good measure
