Hello I just got my torqueboards 218mm trucks and my cloudwheels. When I put the pulley on the wheels and onto the truck the pulley is really tight on the truck and won’t go on all the way. Is there any way to fix this?
Picture plz
Remove hangar material
Remove pulley material
Use different parts
Add bearing spacers (speed washers)
To prevent removing too much material and possibly cause more issues, I’d get a new set of Abec pulleys or if room allows it, try adding on spacers
I’ll try that
I’d rather file the hanger down, it shouldn’t be dangerous as long as you only remove a little
