I need to make space and stop hoarding what i’ll never use again so here it goes
Boardnamics hangers: (both sold now)
One brand spanking new, never even mounted: £35
One reasonably used, dents around the pivot point: £20
I have 4 spare fixed axles to go with them as well (not shown)
Steel pulleys:
17T - one has the flange bent and a 1.5mm key head stuck in it, the other is overall rusty, free with any reasonable order
18T - both in good condition, used them around 3 weeks, £5 for the pair
20T - same as above, but only used 1 week
D596 12s discharge bms: 80A discharge bms if i recall correctly, pure aids for space, i cut the wires at any length i saw fit so every wire needs redoing and you’ll need to source a wiring diagram for it as well. £8
Chubby riptide barrel, slightly too soft for me £3
10x10mm nylon washers. Got machined steel ones now, £1
Venom tall barrel and cone 90A duro. £3
Murdered bn220 hanger, 2 long dickyho mounts, cross brace, and 2 idlers:
Believe it or not the mounts only have a dent each where they normally meet the curbs going down. Everything will be cleaned if there’s any interest. £25 for the set
Vx2 remote, gave it to someone brand new and he tried to slide with my board, not nice. £25 (reserved)
Xtar charger, fits up to 26650 batteries (so both 18650’s and 21700). Takes usb power. Brand new £10
Sold items
10x60mm shoulder bolts. These are for the bn270 only if you put wheels with default bearing sets (meaning 6-7mm bearings and one 10mm spacer plus a washer on each end). These will not fit any extra bearings beyond that length. I’ll include as many 10x1mm washers as you need. £4 for the set (sold)
30Q cells, roughly 100 cycles on them, p1 at 3.12v, rest except the last group at 3.43~3.36. last 3 cells at 0.00v and will be scrapped. £0.5 each, uk only (sold)
Messy battery, 12s4p vtc6 with daly bms, double layer welded nickel and soldered over. For obvious safety reasons everything will be desoldered down to p groups before shipping. Cells performed excellent until i received my upgrade but can’t ask for more than £30 for this mess. Uk only. (Reserved)
And, that was it for now. I have loads of other small stuff that’s not worthy of even a picture to post here. If you settle for something here, have a chat with me, i might have other things you want that i need to get rid of.
