Just keep in mind that foot stop need to support Your position on board, but on second side in case to avoid crash and need to jump out from board, foot stop must not block You. So I would recomended to do it smooth without sharp corners. Anyway grip on board is still fixing Your position.
Thanks guys will think about these suggestions in the next iteration
Made an adapter plate for the davega, would allow to adjust the angle on the go which helps against sun glare. Still have to test it on a ride to see if I actually like it.
