Charger wont charge please help (SOLVED)
My 12s charger wont charge or maybe the problem is on the battery side… Board works and i see no problem on my bms app. But when i plug charger it wont charge.
There is a green and red led even if not connected to board:
Here is some info written on charger:
Fuse of the charger is still good.
Is there any test i could do? Would it help to open charger case? Should i get another charger?
Thank you for your help!
Is the charge port disconnected on the board? Check for continuity issues
Just a heads up your binding is on backwards. More comfy and easier to ratchet it with it on the outside too
That’s normal, the red LED is a power indicator and the green LED is indicating that the charge is “done” (not putting out current)
Honestly sounds like a wiring/connector/BMS issue, not a charger issue. I have the same type of charger for my ebike and it works great.
Thanks guys doe your hints! I found the problem:
The fuse is burnt.
Give it a kiss and tell it thank you before you throw it away. It could have been much worse without it.
