carbon and wood deck 40” $130 in USA
Ok. So 50 decks. What are we at? Not to be rude but that’s not really an answer. How many concrete orders are you at? I understand there is a number waiting for the indiegogo to cancel before ordering, but what is the time line for that as well?
I may buy 2, I may not. I have no clue what is going on anymore.
Edit: Concrete even if not soon most likely has me in.
Were at 8.
Buy two and can cut 15$ off the total shipping for USA , anywhere else take 20$ off per extra board. Just write the details on the form
The indigo ends in like 25 days
I think @hummieee was just saying he’s unclear in the future of the future and what the enclosures may evolve too.
Was trying to say bens doing the boxes unless he doesn’t want to. As far as he’s told me he is. And see if others who have his box also felt they were overly stiff and see if we could get him to possibly make them more flexible.
I don’t see a point in making them flexible? Deck doesn’t flex so why should the enclosure?
The deck does flex to some degree. Maybe I’m the only one who thinks box be better more flexy. Puts more stress on the inserts being stiff and imagine could be made maybe even stronger if flexy n less likely to crack n more so bend. But if no one else agrees…
If you don’t overtight the screws for inserters and make the enclosure screw holes a bit bigger so it can move in x/y I don’t see why it would stress the inserters.
I for one like to have a sturdy enclosure
Essentially making it loosely mounted to compensate. But it’s just my opinion. I like the feel of the deck bending alone. Better than the feel of kydex but still
They could be made with less layers, I don’t think they would be strong enough around the mounting holes?
They could be made with a different cloth, or a mixture of cloths with thicker at the mounting points. They could also be vacuum infused. All these options would mean more expensive materials and more labour intensive=more expensive enclosures…
Ever tried with uni directional going perpendicular? Allowing flex in that long axis. I think u use Matt which is cheaper. Uni seems expensive. If u come up with a mix of materials the same cost but more flex in that Direction be down to try.
Composite perhaps? Just spitballing. I’m satisfied with gf
Everything is possible. Everything carries a cost and time penalty!
we’re only at 19 orders on this.
if someone wants to get a bunch write me and can figure a cheaper cost.
Hey are these decks still available to purchase? To my understanding you are located in NorCal, San Francisco area? If so I am local to SF and can pick up locally.
Great text me and I could bring it to u
610-416-2650
I have a bunch of these decks still. Message me if ur interested. 140$ with shipping in USA
PayPal to humminashadeeba@gmail.com and add all ur info there
What version are the latest ones? Can you provide some pictures? Do they have the cutouts compatible with 21700 cells?
The last one I had you could get a 12s3p 21700 in it.
As far as I know they’re not loads wider like the copy sold by another vendor.
I had someone local who said they could fit two 21700 longwise, perpendicular to deck direction in his version of the hummie.
Mine is like second batch ever, from 2017
Think I got one from this batch a couple years back. Cutout was 585mm x 145mm ish (from memory….)
