Bricked Makerx 4.12
Bricked my makerx so i bought a st link cable but now i cant figure out the connections. Please help.
Probs the 4 pin connector in the center
GND to GND
CLK to SWCLK
DIO to SWDIO
3.3V to 3.3V
like this?
also noticed that i can only fit in 3 wires in on the 4 pin connector in the middle. Do i need to remove the plastic on the side to make it fit?
That is my honest best guess, you probably want to buy a 4 pin pigtail and splice it together
It’s better to get a 4 pin JST PH connector and then connect the ST-Link to those wires but any way you can connect it will probably work.
Don’t shake or vibrate it while flashing firmware, you don’t want a loose connection to cause problems.
Thanks! Worked like a charm with 4pin connector!
