My board works great! The only thing is that it doesn’t turn off… again
Basically I have narrowed down the problem to the bms, the led on my 12v switch connected to stays green whether it is latched or unlatched, I have completely unplugged the switch from the bms and the power stays on. everything looks fine on the bms, is it just a faulty bms again? My bms is from @BuildKitBoards :
https://buildkitboards.com/collections/batteries/products/bestech-bms
I would contact Jared directly hes a reputable vendor and will help you with this.
Edit: You can always add a loop key
