Time for me to sell some spare and left over parts I have laying at home.
Better help me get rid of them before I come to the idea to build one more board out of all that
Some parts, new, some used but all prices are without shipping.
Shipping worldwide shouldn´t be an issue.
Motor pulley 20mm 15T new (2x set screws, no keyway)
set of 2 12mm bore 7$
Motor pulley HTD3M 15mm 17T new set of 2 8mm bore - 10$
HIPS Gold Filament 1kg 9$
FS-GT2E NEW 15$
Battery PCB 18650 3P (1oz copper) stay positive 12x 8$
Etoxx steering damper adapter with hardware 35$
Steering damper, probably defect as it has the same stiffness in every
position) 20$
300x Studs for winter tires 25$ (pic post 33)
Cheap wooden MTB deck new 25$
Cheap wooden MTB deck used with 3D printed concave 20$ - experimental deck, so lots of binding holes filled with epoxy.
11s 5A charger EU Plug, xt90, used 25$ - can solder a Barrel plug if needed
HTD5M belts 15mm 355mm 3x 12$
HTD5M belts 15mm 425mm (Trampa original) 2x 18$
HTD5M belts 20mm 390mm 5x 12$
HTD5M belts 20mm 400mm 4x 10$
2x MAD hubs 90mm sleeves new 10$
Haggy boards Kegel pressfit 36T pulleys with 10mm bearings new 40$
Different sets of riser (see picture) each set of two 5$ or all 3 sets for 12$
ABEC Flywheels 90mm 75a used on my push board only set 75$
FOX Titan race knee pads 30$
Sunkko 787A+ spot welder with pedal, EU plug 35$ plus 65$ shipping internationally
Lipo battery box 55$ explanation see comment 121
2x Maytech 200A vesc based esc 135$ each or 250$ for two
