Hopefully someone can help me here.
I got a bkb duo that comes with the BLE receiver, today I was Adjusting some settings on my Vesc tool app and suddenly it disconnected, I tried to connect. No luck. I opened up the receiver and it shows a blue blinking light. On the Vesc tool app it says “cannot read Vesc firmware” something like that
Been having common problems with my duo and I really just want them all to stop…
“PPM” is the setting that will kill the bluetooth, you want it on “PPM and UART”. But that also depends which remote you have and how it’s connected. UART must be on for the bluetooth to work.
then u r only sending 5v into the usb port in the esc, but won’t have any data transmission. charge only cable is easy to identify, as they have less pins inside the connector itself (not the type A side, but micro / type c…side) usually charge only cable only contain 4 pins. here is the example of type c charge / data cable difference:
