probably, see if makerx comes back with the dimensions
M100 has no mounting holes
Ryan meant the holes for the screws
It was 48.2x48.2
Can you guys please start including mounting holes again? I canāt screw my d75 into a heatsink.
haha, maybe next batch,
Thereās a nice standardized mounting pattern for dual escs that the stormcore and unity uses.
44x15mm square with m3 tapped holes
Using adhesive thermal stickers or double-sided automotive tape?
Now Iām using double sided adhesive thermal tape but itās not strong enough.
Iām curious what kind youāre usingā¦the stuff I use needs pry bars to separate.
I can pull it off fairly easily
Iāve been using this, maybe it could be helpful for your uses.
Something to note about the Stormcore pattern specifically: the set of four holes in the bottom are not centered on the esc. itās closer the one of the sides than the other.
And the two winged holes on the sides are even better because then you donāt have a through hole in the heatsink where water could get in!
Shipping from China
Definitely include mounting holes for heatsinks! Would be good if you could use existing and established patterns. Otherwise one that isnāt stupid.
DV6 one is the best one IMO, except for blind holes thatās kinda annoying
