So I bnought a biunch of Molicel p42A batteries for my build which i’m doing now. Issue, maybe? Is that I bought them last fall and they showed 3.7V on the multimeter, now all of them, but yes all of them, show 3.6V? Do i need to charge them fully before i spot welded them, back up a tenth to 3.7. no, right, then when done with pack I will ultimately charge fully when the full batery pack is charged? am I ok in continuing with the batteries showing at 3.6V on multimeter? thanks!
does your multimeter only show 1 decimal place?
better to weld while lower, potential shorts are less scary
Cell voltage wont make a difference to pack building, just get a better multimeter that shows you more than 1 decimal place
Batteries self discharge very slowly, this is normal. And it’s a good opportunity to check for bad apples that discharged faster than others.
