I have a 10s6p won’t take a charge. Didnt check the initial voltage when I bought it from psychotiller. Charged it when i bought it, and the this week I put it in the board.
I hooked it up to the Unity set it up through the guided set up. It ran on the bench well.
Rode it 4-5 miles as a test, Now when i went back to charge it charger light is on green never goes over to red.
The charger that came with works on another battery so its not that.
When I hit the power button the unity only partially lights up. The only way the unity powers up is if the battery is hooked up to the charger.
When it is hooked up to the charger the motors spin but not at full power. And when i disconnect it the unit completely shuts down.
How do I test it to figure out what the problem is
My feeling is it is a loose wire that got disconnected when i rode it which is why it wont charge.
But what is the mechanism that allows the board to be powered up while plugged in but not take a charge?
Any help is appreciated
