Hey guys- working on the mechanical components of my flux- running into an issue here w the amount of threading going into the rear axle- here’s a photo of front vs back- any thoughts?? Should I just drop some thread locker on here and hope for the best? I don’t feel like it’s too secure
You do have speedrings on the inner and outside bearings right?
My advice would be to just file down the crossbars if you can… Its not safe to have the nuts on as they were shown. You could in the second image reverse the nut so the nylock part goes on first, that would make it safe
I had this same issue with mine. I was using the lacroix motor mounts with fivestar hubs. I could not find a pulley that was skinny enough to work, so I 3d printed my own. I modified this https://www.thingiverse.com/thing:3932609
I used riprapper carbon-fiber infused nylon and they have held up for over 2000 miles now with little signs of wear.
Its not the easiest solution, but it works.
