I believe @Jeep might be the first person outside apex who had the BN drive but has just fitted his Jump drive. im sure after a few rides he will be able to give some feedback.
@haven jump drives ratios are slightly more than offered by others however as previously said by others here, there are many routes to get to more speed.
I think your 4.4:1 ratio is plenty fast. 12s/190kv/190mm wheels gets you up to 35mph loaded. Probably good enough for most people. I was just sharing because Haven asked for the differences to be pointed out. Not intending to put down the jump drive in any way
Will you guys offer adapters for matrix II in the future?
All outstanding Jump Drive and Chain Drive orders are boxed up and ready to ship tomorrow, so keep an eye on your inboxes.
There’s also a few extra sets of each boxed and ready to ship immediately, so if you want some shiny on its way to you this week then get your order in quick before these get dispatched tomorrow.
I’ve had these drives in hand for two days now. They are beautiful. The fit and finish is better than expected, to be honest.
I have yet to run them, but it’s coming soon.
Very impressed with these drives after unboxing them. The gears fit together incredibly, fun to play around with. Can’t wait to get them on! If I can manage to get tune them to be as quiet as @JoeyZ5’s BN drives, I might consider using these for a street build as well.
P.S. Use green threadlocker (638 or 648) for the motor pinion on non-apex motors (without the second circlip). Instructions only mention red and blue for assembly, which is a minor mistake.
In the instructions we recommend LOCTITE 270 or 278 for high strength, both are green high strength retaining compound. But yes 638 or 648 should also do the job.
We should probably call this out as retaining compound rather than thread locker in the instructions to so I will make sure that gets changed and clarified.
@rusins I’ve also heard that if your using motors without circlips it can be a good idea to hit the shaft with a little coarse sand paper quickly just to rough the surface a little and give the LOCTITE something to grip to better.
Once a position is chosen most users will likely never want to remove these and never want them coming loose. Green locktight is a more permanent and lower maintenance option.
Obviously more experienced DIY guys know what they may want to change in the future so use your best judgement if you plan to take them off again.
You just dont really want to under locktite them and lose them during riding.
