Anybody here put metal hubs/pulleys on Lacrox Barrell?
Thinking about replacing the MBS plastic hub
You should be able to use most mbs pattern wheels, provided they have a 28mm bearing seat.
That would include newbee, new mbs, etc
I think most if not alll of the MBS rims have a 28mm bearing seat. Any other recomendation for a rim ( the MBS rockstart2 aluminiums are tough to beat ),???
I cant believe lacroix wouldnt put metal rims on even their “entry tier” boards (jaws2.0 , barrel, nazari)
28mm bearings are stronger anyway, I wouldn’t put anything with a 22mm bearing on a board with large axles unless absolutely necessary
CNC machined rims are expensive. IMO it’s better to have some good cheap rims as a starting place, and then let people customize to their own desire.
