I’ve been under the impression the stator size on the 89/96’s is very similar in size to an 80mm can, but with the added outer bearing a normal eskate bldc motor doesn’t have for a bit more strength or lifespan or whatever.
You’re probably right, but on the spec sheet of the motors it says the 6389 has a max current of 80a vs the 6374s max of 65. Its also about 1kw more powerful. I’d assume that counts for something even if its not huge.
Lacroix/maytech have 10mm shafts so you need to make sure he has a 10mm shaft option for the helical motor gear. He did when I asked for straight cut, but only in higher tooth count.
My reasoning for going with the lacroix ones was that they are apparently sealed and splash resistant or something - do you think there’s any real benefit to having that compared to the open design of the TB motors?
Honestly. @Skyart said everything there is to be said. 6380s will do you good.
If I were you I wouldn’t waste my time with anything else “specially Maytech 6396s”
I believe that tb6380s are also more powerful than maytech 6396s
Or maybe you wanna look into flipsky 6384s. New model became available not long ago. They’re nice and already factory battle hardened at an amazing price.
