Me toooooooo! I’m FINALLY building on my v1 haya. Got it just before Christmas 2018 haha. I’ll defo make a build thread for mine too. This is gonna be an amazing build man.
I’m seeing 52 cells in there. What’s gonna be your batt config? What kinda BMS?
Edit: ahhhhh 13s. Derp, missed it.
I have ordered this BMS.
I used it a lot in the past for ebikes and other projects with much more power.
It’s a really good an reliable BMS with connectivity perks.
I will look into how link the UART BMS out to the VESC
Yup at first I wanted to do actually a 13S4P with 21700 but would only have space for a mini BMS with discharge bypass.
I decided to go the security way
I cannot count the number of packs I destroyed with poor balancing.
It should actually fit perfectly inside.
If not it’s ok I will just use it for another project.
13S should be fine if programmed properly, max voltage of 13S is 54.6 volt and I will charge the battery to 52 V to avoid high Voltage spikes that could damage the ESC.
Wish me luck !
Every electric powered system I use today is in 48V so it is just easier for me to stay the same battery wise so I can use the same chargers.
Built the battery - BMS not arrived yet -
Installed the trucks - will add risers as there is wheel bite
I just have to do a couple of holes for on/off and charge port
