Sickboards have classic ones in raw in stock. Ofc, these ones appear to be compatible with their drives, so they’re even better I suppose
In January will be done
Would it be possible to get a narrower hanger for the FatBoy Mini Urethane Gear Drive V4? I want my wheels to be as close together as possible, and I’m willing to use smaller motors than pictured above to achieve this. Modern downhill racing setups are using hanger widths in the range of 110-155 mm, but I’d be willing to settle for anything in the 160-180 mm range for a dual motor drivetrain.
For example, what is the theoretical minimum width hanger for use with the Hoyt St 56x53 pocket rocket motors?
What benefits are you hoping to get from narrower trucks, besides a little more agility in trade of stability?
This has been discussed and is debatable…
It works with trampas/mbs tires some aliexpress and etc places
You can still grab namo it fits ecalibers with 6355 motors but not new mini as they need space for bearings and etc
Do the Fatboy SS Mini Gear Drives work with 6880 motors? I see in the pictures that there is a screw right at the edge of the motor, but maybe that can be screwed in before the motor is attached?
Much, much more grip on high G turns.
namo?
Regardless of whether it’s the Mini or the Nano, I’d still love to use FatBoy hangers if at all possible (for strength and maximum coolness). I was just wondering if it would be possible to make a narrower FatBoy hanger for those that want to go narrow.
Love these gear drives and stoked to see them more available!
Would love something dumb like a 80-100mm hanger with 50mm of axle with maximum motor mounting surface for an ultra narrow, diagonal build.
I talked with @3DServisas he said he will check if it’s possible to do it simply without making new ones
Is that connected via bluetooth?
Is there a possibility to plug balance leads i to it so that it also displays individual cell voltages? I would buy 5 straight up
At the moment only USB, but I can figure out something regarding this stuff. I did not wanted to make it a little bit overkill for switch…
Bluetooth would be possible via like HM10 module, regarding reading voltages is also possible by adding additional module I guess. Will have to figure out something
