Enlightenment incoming
For the antispark switch, you can search the flipsky site to see what they look like. They can sell them separately. As for the voltage switch on your esc it is simply meant for the sensors on the motors. Some need 3.3v and others need 5v. On my dual, I simply have both voltages in the connector. You can switch what yours gives out.
word up yeah I’m planning on doing loopkeys anyway I was just wondering what all this talk on the flipsky website was about “anti-spark” because the FSESC doesn’t actually come with an antispark lol
The non-‘simplify’ version does come with an antispark, that’s the 3 mosfets you have indicated.
the reason they tell you to not plug it in without the led is because the mosfet gates float, and that’s bad for the switch.
you can mitigate that with the resistor, but there’s not much reason to have one esc with an antispark and the other not, especially if you’re going to be using a loop-key as your on/off switch.
That’s where the suggestion comes in to just jump the switch.
you can do it more properly by bypassing the fets themselves, but the first is maybe a less stressful solution depending on your comfort level with soldering
I have the 6.6 with the antispark. I jumped the pins for the switch but one of the three mosfets pictured above came loose resulting in a shutdown of the whole esc. Will someone please provide some detail as to how I bypass the mosfets? What do I do?
-find suitable conducting material to bridge the pads with (leave the gate pads be).
I have had in mind doing this bypass on my fs6.6es for along time since I believed the antispark would be the first thing breaking on this esc. Perhaps that would avoid blowing up the pcb when it fails.
Never got around to it though.
So after removing all three mosfets, I could just solder on a piece of copper or something like that all the at across all three spots where the mosfets were? That wouldn’t cause a short?
Sorry for my idiotic questions, but can I put a piece of copper all the way across all of the pads, or should I place it on each pad individually to keep each pad separate? Thanks again!
