ignore so many washer on the Rev motor.
oOur pionion support quick swap! no matter which brand (only 8mm shaft, shaft length under 30mm)
it supports grubs screws also, there muti way you could mount your pionion!
What’s the total length of your stock pinion gear?
What’re the gear ratios can you get?
Is there any problem with this black ring rubbing against the pinion gear and the gear housing when operating?
pionion height 14.75mm, we have tested this methods for a while haven’t found any issues yet. as longer the rubber ring is well lubricated
when will it be available to purchase? ![]()
So the same gear driver can be used for all street Kegel brakes and for standard BMS tires from 6" to 8"?
one more week
Tell us more about that connector in the photo please
Air-brake flaps, duh.
This the new connector we offer for our next series of the board, based on the factory test report, this connector could go through 50a continuous.
Each large bullet can do 50a? Or in total? I wanna use these motors but the 50a may be a tad limiting if it’s total
each is rated lower idk, the bullet inside is the same like Mr60. which is enough for electric skateboard. it rated for 50a continuous maximum temperature 50c, for the brust..it will eat it for no problem.
Would you be willing to send me a set to put on a very powerful board to convince others that they work at these high power levels?
just the connector??
Enough for a 2wd board please.
Throw in another set for a 4wd board if you’re feeling generous. I promise I’ll make content
This product looks incredibly creative and gorgeous.
I want that too. Lol
