So all of my boards run 10S battery. It’s just something that has happened and now I like the consistency. I’m building a 10S10P battery that I can Velcro to the top of any of my boards and have crazy range.
Why are all the batts unwrapped?
I think they are wrapped in clear heatshrink, well I hope they are
How are you reaching down to the positive contact for the connection? Spot-welded nickel strip or will this be a compression pack?
For those who don’t know this cell doesn’t have a standard top contact, it is recessed and has a fuse wire/strip welded to it. When you buy these cells they have had the fuse wire clipped off, standard top contact structures welded on, and wraps added.
You cannot spot weld because the positive terminal is aluminum. The 3D print has a dimple which pushes a wire mesh into the terminal it’s kinda hard to see in these photos but it’s the best I have. They eventually get screwed together to keep the compression.
Thanks for the photos!
Ahh….so Tesla’s fuse wire/strip connection is laser welded then?
Pardon the messy workshop
If it’s not messy then you’re not doing any work.
It was definitely a learning process removing and cleaning those cells but after trying a few different things I figured out how to do it pretty quickly. It had 396 cells on it and I’d say it would probably take me about 8 hours to remove and clean all the glue off all of them.
Is there a risk of the braid pushing into the negative rim of the cell?
I suppose there is always that risk. I put a fish paper ring down and then wrapped over that.
I’ll be using the same compression mechanism, tell me your feeling of it when you assemble it !
I already have this 10S2P pack completed and it is great as long as you have quality 3D prints you’ll be fine. I have 20 miles on that pack and I’m mailing it off to a client.
They are not the best performing cells in the world but I paid $1.25/cell for them so I can’t complain too much.
Thirty-five 10S chargers and 15 boards later, this hits me so hard. And also 12S LiFePO4 charging to 42V.
Nice. I did a external 10s pack a while back ago for longer range.
I’m able to go just over 40+ miles if I keep the Watts/miles reasonable with the pack onboard and the one I carry.
This is a 10S10P pack, but with 18650s. (Panasonic PF)
So I’d imagine with conservative settings on polyurethane you should be able to beat that. For reference I am 210lbs (96kg)
On my primary board I have a 10s7p 25 r (17.5ah) and I can get 30 miles on that. This 10S10P will be 43ah. Combined I should get close to 100mile range. That board is on 97mm Thanes.
